hello how can i access to the type the witdh and the precision of a attribute to store them in a file or in others attributes Thanks
  • Aug 18, 2022 4:09 PM UTC
  • 41 views
@brigousse​ You can use the Schema (any Format) reader to return the schema of a dataset. An alternative is to use the FeatureReader transformer and use Features to Read: Schema Features. The <schema> output port will give you the schema of the feature
