Hello everyone, I am doing the geocoder exercise and keep getting this warning(see below). Any help would be greatly appreciated!
  • February 25, 2023
  • 77 views
DEBUG: urllib3.connectionpool Retrying (Retry(total=7, connect=2, read=2, redirect=None, status=2)) after connection broken by 'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1129)'))': /?format=json&q=Willow+Street%2C+Vancouver%2C+British+Columbia%2C+V5Z
  • February 27, 2023
@embee​ Are you referring to the article Geocoding Addresses? Which exercise?
Which version of FME are you using? Perhaps you're on an older version of FME that has an out of date API in the Geocoder.
