Hello everyone, I am doing the geocoder exercise and keep getting this warning(see below). Any help would be greatly appreciated!
  • Feb 25, 2023 11:38 PM UTC
  • 121 views
DEBUG: urllib3.connectionpool Retrying (Retry(total=7, connect=2, read=2, redirect=None, status=2)) after connection broken by 'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1129)'))': /?format=json&q=Willow+Street%2C+Vancouver%2C+British+Columbia%2C+V5Z
@embee​ Are you referring to the article Geocoding Addresses? Which exercise?
Which version of FME are you using? Perhaps you're on an older version of FME that has an out of date API in the Geocoder.
