Getting Errror cannot be converted to esriGeometryPolygon
  • Jul 1, 2022 9:52 AM UTC
  • 505 views
asadamjad
Participant
Forum|alt.badge.img+12
I m trying to get the data from KMZ and push it to the ArcGIS portal everything is fine but getting errors in the writer
<class 'FMEobjects.FMEAggregate'> cannot be converted to esriGeometryPolygon
anyone knows where I'm wrong
rahulsharma
Hi @asadamjad​
The reason that you are experiencing the errors is due to the fact that ArcGIS Portal Writer does not handle Aggregates geometry, as the FeatureService needs to be only a single geometry feature see documentation here
If you look under Geometry Type Aggregate.
To be clear, FME can only support Homogeneous aggregates so any input features with fme_aggregate  can’t have fme_collection as a fme_type.
WORKAROUND:
The workaround is to convert those geometries into Homogenous aggregate using Deaggregator and Aggregator (in succession). See the sample workspace attached.
