GeometryReplacer Not working on utf-16LE strings (from SQLExcecutor)
  • Jul 20, 2023 8:16 AM UTC
  • 40 views
itsmatt
Forum|alt.badge.img+48
I'm querying a table with geometries (PostGIS) and the resulting geometry column when run through a GeomtryReplacer just ends up with an empty geometry. The encoding is Hex Encoded OGC Well Known Binary.
If I copy the string (with copy paste) into an attribute creator then the geometry gets replaced.
The only differnce that I can see is that the string attribute from the SQLExcecutor is encoded as utf-16LE and the attributeCreator string is in UTF-8.
It's kind of strange because another geometry column in the same database comes in as a utf-8 string.  It's an envelope.
This is the string/geometry in question:
01060000A0E86400000100000001030000800100000005000000333333335C021C41000000C052BF54410000000000A05C403333333354021C41000000C052BF54410000000000A05C403333333354021C41000000C052BF5441CDCCCCCCCCEC5C40333333335C021C41000000C052BF5441CDCCCCCCCCEC5C40333333335C021C41000000C052BF54410000000000A05C40
I was previously casting the Geometry using AS_STBinary() and then replacing using using OCG Well Known Binary. This was working but the query was a lot slower. Not casting (at least for the specific query I'm using) turns out to be much faster.
Anyone got any ideas for a workaround here?
itsmatt
  • Jul 20, 2023 8:21 AM UTC
UPDATE - If use an AttributeEncoder to cast to UTF-8 then it works. Not ideal but a workaround none-the-less
