geojson with fanout missing filetype extension on export
  • Jan 11, 2021 12:09 PM UTC
  • 100 views
so_much_more
As the question describe. I have exported geojson to multiple files but I realize they are all missing the extension which make the program I will use the file in unable to read them. Is this a bug or how do I fix it?
  • Jan 11, 2021 12:39 PM UTC
It's up to you to add the extension to the fanout expression, e.g.
@Value(MyFilename).json
so_much_more
  • Jan 11, 2021 1:23 PM UTC
I see, that is what I ended up with, but the file name looks a bit weird. It add a ".geojson" before the extension. But it works
@Value(areaname).json -> areaname1.geojson.geojson
  • Jan 11, 2021 1:40 PM UTC
Check the actual contents of the attribute areaname just before it arrives at the writer, e.g. using a breakpoint, Logger or Inspector.
so_much_more
  • Jan 11, 2021 2:57 PM UTC
Did that with the logger. The attribute name is as "expected" without the (.geojson) in the name. A bit surprised how it evaluate the name. Maybe I am still doing something wrong. But I have just added @Value(areaname).geosjon in the expression option
