One way to do this is by using the ChangeDetector.
Have you some example please?
I need to analyse the geometry mainly! No have attributes in these datasets. Thank´s
Sure. I reprojected the data to a projected system in meters, so the ChangeDetector's Vector Tolerance could be set to a realistic value.
Good, but no sucessful. In INSERT (TARNAT) have polygons equals the ABIGOBAL. look below:
the polygons do not complement each other but fall on top of each other, in a few cases they complement each other. Thank´s
