Found complementary polygons
  • Jul 12, 2023 6:45 PM UTC
  • 59 views
arsouzaesilva
Participant
I have two polygons dataset. I would like to find the differents polygons between them. In other words, which polygons have in dataset A that do not have in dataset B. In opposite too. I used spatialrelator and PointOnAreaOverlayer already, but no success. Attached follow my datasets.
Thank´s
nielsgerrits
Forum|alt.badge.img+67
One way to do this is by using the ChangeDetector.
arsouzaesilva
Participant
  • Participant
  • Jul 12, 2023 7:11 PM UTC
Have you some example please?
I need to analyse the geometry mainly! No have attributes in these datasets. Thank´s
nielsgerrits
Sure. I reprojected the data to a projected system in meters, so the ChangeDetector's Vector Tolerance could be set to a realistic value.
ChangeDetectorSampleChangeDetectorSampleResult
arsouzaesilva
Participant
  • Participant
  • Jul 12, 2023 8:15 PM UTC
Good, but no sucessful. In INSERT (TARNAT) have polygons equals the ABIGOBAL. look below:
1
2
the polygons do not complement each other but fall on top of each other, in a few cases they complement each other. Thank´s
