Hi @dionysios , if you need to split a text line by some pattern and create new lines for each resulting split element, combination of the StringSearcher and the ListExploder might help you.
I don't know if it's correct, but it seems that "A*N*-EWC-****" (* is a digit) is the basic pattern and sometimes suffix "-a" or "-b" is added.
Could you please elaborate the correct pattern that should be applied to split the text line?
I'd follow this approach, using the regex functionality in the string searcher will allow you to split out the individual parts
1(A\dN\d-EWC-\d{4}(-[a-zA-Z]\d?)?)
'A\dN\d-EWC'- will find a string that begins with an 'A', followed by a digit (0-9) followed by a 'N' , follwed by a digit and ending with '-EWC-'
'\d{4}' will find four digits in a row
'(-[a-zA-Z]\d?)?' is an optional statement (denoted by the '?' meaning zero or one). It will match a string that begins with a '-' followed by any letter (case insensitive) follow by an optional digit
@hkingsbury @Takashi Iijima hi guys, thanks for the reply. The problem is not really finding the pattern which its really always same format, easy to use a regex. I just cant make it write on excel as a list, one below the other. This however gives me some ideas, probably find the values with attribute manager before writting them on the excel. Thank you both
Do the linefeeds already exist in your string?
Have you set the wrap text option on the attribute in the formatting options?
hi @ebygomm yes i did try that one too. It did not work, i guess because i am using the attribute manager with @values from different attributes. i am going to play a bit more with different options.
So your AttributeManager looks something like this?
If the linefeeds are present and the column is set to wrap text it should just work.
That is exactly how it looks but it didnt work.
