FME Server REST API Return File Extensions for File Upload
  • Feb 20, 2022 10:00 PM UTC
  • 0 replies
  • 70 views
warrendev
Forum|alt.badge.img+28
I've built a python fastapi web application using the FME Server REST API and was wondering if I'm overlooking where the file extension filters are returned for any file parameters. While I see all of the other parameter information, I am not seeing the file extensions specified in the workspace for a parameter. It does not show this in the REST API call for /repositories/< repository >/items/< item >/parameters, so I was wondering if it is somewhere else or not available at all.
Is this a limitation to the FME Server REST API perhaps? The reason for this is that my application is fully dynamic, so the FME workspace drives the creation of the form inputs.
