FME Server and ArcGIS Server + ArcGIS Server Basic License
  • Feb 16, 2023 12:44 AM UTC
  • 568 views
renosungis
Forum|alt.badge.img+3
Hi All,
Does anyone have experience installing ArcGIS Server with ArcGIS Server Basic license on the same Windows Server hosting FME Server?
Do I need to complete our ArcGIS server Setup Wizard? Or as long as I have ArcGIS Server installed with ArcGIS Server Basic license...I am ready to have automations accessing enterprise level SDE and read/write data from our enterprise GDB without creating a new site? or do I need to "Join Existing Site"?
Please help :)
Many thanks,
Reno
Best answer by theoconsortech
When installing FME Server with ArcGIS Server (when used for licensing purposes only), there is no need to create a new site. The only thing to do is to install ArcGIS Server (with the basic components) and authorize the software.
Also make sure you have compatible FME/ESRI versions: https://community.safe.com/s/article/notes-on-fme-and-esri-versions-and-compatibility
renosungis
  • Feb 17, 2023 1:40 AM UTC
New site need to be created :)
theoconsortech
Forum|alt.badge.img+19
  • Apr 28, 2023 3:18 PM UTC
renosungis
  • Nov 16, 2023 1:41 AM UTC
Thanks a lot @theodrogo​
For FME Flow needing to run anything using arcpy, I need to use ArcGIS Server Advanced right? :)
Cheers,
Reno
theoconsortech
You're welcome @renosungis​ !
For your second question, a standard ArcGIS Server license should be enough if there's nothing specific apart from reading / writing ESRI classic formats.
