FME running much slower on my machine vs another.
  • May 12, 2020 2:08 PM UTC
  • 8 replies
  • 259 views
bjudes
Forum|alt.badge.img+10
As the title says, FME is running much slower on my machine vs a colleague running the exact same process with a similar spec machine. The process took them 2hrs 48 minutes, while I had to kill the process after 4 days of running.
We tried changing the fme temp directory off my C drive and onto another and I noticed something in the log file. At the start of the process the log file states that the temp file is:
2020-05-12 14:33:56| 0.2| 0.0|INFORM|System Status: 2.78 TB of disk space available in the FME temporary folder (U:\\osihfile04\\Land_Cover_Store\\FME_TEMP)
However later on at the end of the log file it states:
|1405.6| 0.0|STATS |Stored 51098 feature(s) to FME feature store file `C:\\Users\\jonesD\\AppData\\Local\\Temp\\wb-inspectors-vsYHBZ\\inspector.ffs'
2020-05-12 14:57:24|1405.6| 0.0|INFORM|Saving spatial index into file 'C:\\Users\\jonesD\\AppData\\Local\\Temp\\wb-inspectors-vsYHBZ\\inspector.fsi'
2020-05-12 14:57:24|1405.7| 0.0|INFORM|Finished saving spatial index into file 'C:\\Users\\jonesD\\AppData\\Local\\Temp\\wb-inspectors-vsYHBZ\\inspector.fsi'
As you can see at the start of the process it is saying it is writing the temp files to U drive while at the end it seems to be writing the files to the C drive. Would this make any difference?
Thanks for any help.
B
You can set the path for the temp directory to a local directory.
https://knowledge.safe.com/articles/176/fme-temp-environment-variable.html
Also, setting the log file to run locally can increase speed dramatically. I'm assuming U: is a mapped drive on the network and will slow things down.
bjudes
  • May 12, 2020 2:22 PM UTC
Yes we had it mapped to my G drive which is a local ssd. But it was slow here. This drive had about 500gb of free space. After this IT wanted to map it to a drive with more space, so they mapped it to U drive, which has 2.5tb of space. It is a network drive, but this is an experiment and not a long term solution. I'm more interested in the fact that at the start of the log file we are sending temp files to U and at the end we are sending them to C. Is this normal does it matter?
Thanks
B
Thanks
B
It's not supposed to reference drives that aren't in the process or environment variable.
Verify your environment variable is correct by opening a command prompt and typing;
echo %FME_TEMP%
If that is correct, open the workbench with notepad and see if the u: drive is referenced. That will give you a better idea of what it's doing. Always use notepad btw. You can modify it and it won't corrupt the workbench.
helmoet
Forum|alt.badge.img+8
  • May 13, 2020 6:38 AM UTC
Hi @bjudes, why use inspector if speed is critical?
bjudes
  • May 13, 2020 2:10 PM UTC
Update, I rolled back my version of FME from 2019.1 to 2018.1 and the workbench has now run with the same speed as my colleagues was running. Down from 4 days (and running) to circa 3 hours.
However, going back in versions appears to have thrown up another problem. I am trying to run about 5500 features through the AreaOnAreaOverlayer and it is giving me 80000+ features on the output. This was never a problem with the previous version. Does anyone have any idea why this would happen?
Thanks for any help you can give.
B
bjudes
  • May 13, 2020 2:12 PM UTC
That is a fair observation, I didn't think of it. Removed them. Thanks
Forum|alt.badge.img+54
  • May 13, 2020 2:38 PM UTC
B
Is the tolerance set to the same value?
bjudes
  • May 13, 2020 2:41 PM UTC
Hi @ebygomm, thanks for the reply. Yes the tolerance is set to Automatic on both. I've attached a log file if that is any help.
Thanks
B
FME_LOG_FILE.txt
