FME FLOW 2023, Is there a way to change the color of the blue ring logo on the browser tab icon?
  • Nov 16, 2023 7:06 PM UTC
  • 7 replies
  • 224 views
kbraun77
Forum|alt.badge.img+9
imageI have two FME Flow servers and I'd like to be able to change this color to easily be able to tell them apart when I have multiple tabs open.
itsmatt
Forum|alt.badge.img+48
  • Nov 17, 2023 8:25 AM UTC
I haven't tried but I think if you changed the favicon in the installtion folder it should work
I think this is the path to the file you would need to change.
"C:\\Program Files\\FMEServer\\Utilities\\tomcat\\webapps\\ROOT\\favicon.ico"
Read more about favicons here: https://en.wikipedia.org/wiki/Favicon
Forum|alt.badge.img+63
I wanted to suggest that too, but I'm not sure that's the correct file. On my local FME Flow installation it still shows the old Safe logo whereas the browser tab icon is the new one:
imageSo there must be a different favicon.ico somewhere...
itsmatt
  • Nov 17, 2023 10:19 AM UTC
Aha! the plot thickens!
Got it. The developer tools show the favicon is read from http://[hostname]/fmeserver/images/favicon-fme-flow.svg, which in my case is in C:\\Program Files\\FMEFlow\\Utilities\\tomcat\\webapps\\fmeserver\\images
Yep, just tried it. You do need admin rights (on the machine where FME Flow is running, so not in Flow itself) to be able to replace the file, but it works.
itsmatt
  • Nov 17, 2023 11:24 AM UTC
Ah yes - I also just double checked and found the same path
"C:\\Program Files\\FMEServer\\Utilities\\tomcat\\webapps\\fmeserver\\images\\"
kbraun77
  • Nov 17, 2023 2:07 PM UTC
Thank you!!
