FME floating licences support IPv6 and Direct Access
  • Feb 27, 2020 5:02 PM UTC
  • 0 replies
  • 53 views
lbrochard
Hello,
I have a FME floating licence server.
I can't use it FME2018 with DirectAccess.
I have try this : https://knowledge.safe.com/idea/36924/fme-floating-licences-support-ipv6.html
but this does not work.
I have the error message :
2020-02-21 12:26:02 The FME license has failed, so FME will now attempt some diagnostics for the floating license
2020-02-21 12:26:02 Checking for a floating license file in the locations: "C:\applications\FME 2018\licenses\fme_license.dat" "C:\ProgramData\Safe Software\FME\Licenses\fme_license.dat" "C:\Users\USER\OneDrive\Documents\FME\Licenses\fme_license.dat" "C:\Users\USER\OneDrive\Documents\FME\Licenses\fme_license.dat"
2020-02-21 12:26:02 Found a floating license file: 'C:\ProgramData\Safe Software\FME\Licenses\fme_license.dat'
2020-02-21 12:26:02 Reading the floating license file: 'C:\ProgramData\Safe Software\FME\Licenses\fme_license.dat'
2020-02-21 12:26:02 License file specifies server # 1 as servername.domain (and port not specified)
2020-02-21 12:26:02 FME Licensing Assistant specified the server as servername.domain (and port not specified) so any existing license files will be ignored
2020-02-21 12:26:02 Checking for environment variables that may affect the connection to a floating license server
2020-02-21 12:26:02 Checking whether an IP address can be determined from the server
2020-02-21 12:26:02 Server servername.domain could not be resolved to an IP address. Please contact your systems administrator
2020-02-21 12:26:02 For floating license service troubleshooting help, visit http://fme.ly/FloatingLicenseHel
Could you help me please?
Thanks !
Ludovic.
