FME Desktop and UNC Paths
  • Nov 15, 2012 5:07 PM UTC
  • 128 views
geogeoff
Is there any advantage in using UNC paths rather than mapped paths in FME Desktop? Wouldn't UNC  be better for batching and portablity?
Cheers,
Jeff N
amaresnest
Forum|alt.badge.img+8
  • Nov 15, 2012 5:48 PM UTC
Hi Jeff
I have used UNC paths with desktop a few time. Mainly when i had a dir structure with dependant files etc. Worked fine for me and as you say meant in theory i only had to set one root folder location when porting around.
Cheers
Adie
  • Nov 15, 2012 7:40 PM UTC
UNC paths are necessary for me if I want to publish my workbench to FME Server.  Our servers do not have mapped network drives.
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • Nov 15, 2012 9:33 PM UTC
I'd say it depends on your organisatinal structure.
Some companies change which servers are tied to a mapped drive on an infrequent basis and then rollout the new mapped drives via Active Directory to all staff. In such a case, it would be beneficial to reference the mapped drives as the server names would change.
Otherwise, if a company isn't using fully standard mapped drives or if the servers are generally going to be static for the next few years, it may be safer to use the UNC paths.
Again though, I don't think theres a standard answer for everyone.
