FME Desktop 2022: What is the equivalent tool for ArcGIS “join field” in FME?
  • February 18, 2022
  • 28 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out if there is a tool that’s equivalent tool for ArcGIS “join field” in FME.
For example, in the screenshot below, I wanted to join the attribute table of the layer L1 with the table T1 to end up with having all the fields of table T1 in the layer L1
Clip_59Clip_60
Best answer by chrisatsafe
FeatureMerger should do the trick, where L1 is the Requestor and T1 is the Supplier.
chrisatsafe
  • February 18, 2022
jamal
  • February 19, 2022
Thank you very much. It works fine
Clip_69
Clip_70
Clip_71
