FME Desktop 2022: Disaggregating two polygons gets them unexpectedly three,
  • Mar 9, 2022 7:21 PM UTC
  • 10 replies
  • 108 views
jamal
Forum|alt.badge.img+5
In the screenshot below, I got two polygons. However, as they are disaggregated I got three while they should remain two in this case as they are physically two from their native source with no reason to become three.
What could be the issue here?
Clip_222Clip_223Clip_224
Clip_225
The data and workbench are attached
Best answer by hkingsbury
At all. I don’t expect to have 40 under 90.
Have a look at the attached
hkingsbury
Forum|alt.badge.img+73
  • Mar 10, 2022 1:19 AM UTC
let call the two feautres you read in from the DWG, 'G1' and 'G2'
G1:imageG2:image
G1 is pretty simple, just a plain polygonimage
G2 is a more complex geometry and has two parts a, polygon and a donutimage
The polygon part of G2 is the same geometry as G1 (the red dot is the first vertex). It is by itself, a simple polygonimage
The second part of G2 is also a complex geometry that has multiple parts to it. Because it is a donut it has also has two parts, the inside and the outside (lines).
So, because G1 has one part and G2 has two parts, deaggreating gets you three parts. I think whats confused you here as that there are multiple geometries representing the hole in the large geometry
jamal
  • Mar 10, 2022 5:59 PM UTC
Thank you for the very useful input.
But how can I end up with just having two polygons to be equivalent to what we have AutoCAD so that as we convert data from CAD to GIS they got the same?
Currently, if the “AreaOnAreaOverlayer” tool is applied then it ends up with having an overlap at the donut which is not equivalent to what we have in AutoCAD. In AutoCAD, we don’t have intersection between these two polygons at least at the visual level
Clip_228
Clip_229
hkingsbury
  • Mar 10, 2022 7:20 PM UTC
Clip_228
Clip_229
I'm assuming that you're required output is the donut and the geometry . (more on that at the bottom)
FME is showing exactly what the geometry is, you mentioned that visually they're the same in CAD, but in FME they're not. This comes down to multiple factors, a lot of software and formats (CAD, ArcGIS, GDB, SDE, ArcGIS Online to name a few) will have data level precision's that default to a certain value, for 99.9% of use cases, these precision's are perfectly sufficient. (eg coordinates are rounded to 5 decimal places).
The thing with FME (to the extent of almost being a 'fault') is that it doesn't have these limits in place, if a coordinate has 10 decimal places ultimately placing it at an accuracy of a fraction of a mm, then it will do that, if you're comparing this coordinate in another piece of software that rounds it to 5 decimal places, then those two locations will be different. Again, if this coordinate exisits in a CSV and you're comparing it to the 'same' point in SDE, it is highly likely they will be 'different' yet not on a level where you can visually see it.
Back to the donut question. Because G2 contains two geometries, you can deaggregate that and use the two individual parts.
Use a PartCounter to get the counts of the number of parts, then use a tester to find which one has more than two parts. Then deaggregating the result will leave you with two geometries - the smaller polygon and the larger donut
jamal
  • Mar 10, 2022 7:52 PM UTC
Thank you for the prompt help.
In terms of data, the polygon that has the color “90” is lost! And thus, as it’s interpreted to GIS these two polygons will have the color “40” which is inconsistent with what we have in AutoCAD data
What’s required here is to have just two polygons: one with color “40” and the other is with “90”
Clip_233Clip_234
hkingsbury
  • Mar 13, 2022 6:51 PM UTC
Clip_233Clip_234
Are you expecting your large area to be a simple polygon (no hole) or a donut (has a hole)?
jamal
  • Mar 13, 2022 8:40 PM UTC
Whatever that ends up with having just two polygons after deaggregation: one with color 90 and the other with color 40 to get equivalent to what we have in AutoCAD
Clip_256
Clip_257
Clip_258
hkingsbury
  • Mar 14, 2022 12:20 AM UTC
Clip_256
Clip_257
Clip_258
For 40, do you expect there to be a hole in it (a donut)? If you turn off 90, does 40 continue under it?
jamal
  • Mar 14, 2022 11:25 AM UTC
hkingsbury
  • Mar 14, 2022 6:51 PM UTC
jamal
  • Mar 14, 2022 8:28 PM UTC
Amazing hkingsbury. It works like a charm
Very much appreciated
Jamal
Clip_262
