FME change OLEDB connection driver version (v19)
  • May 18, 2022 5:41 AM UTC
  • 370 views
kieranmg
Forum|alt.badge.img+3
Having recently disabled older SSL & TLS versions on our servers, fme desktop/server sql connections have broken. The workaround for other applications was installing OLE DB v19. I've tested this using a blank .udl file and confirmed it works creating a db connection with v19 but not the other.
imageHow do i get fme desktop/server to recognize this new version? As the error still suggests its using the basic oledb driver.
The connection string fme complains about i think should have'provider' set to MSOLEDBSQL19 instead of just MSOLEDBSQL
Any suggestions are appreciated! 🙂
kieranmg
  • May 19, 2022 12:27 AM UTC
OLE DB 18 resolved this issue
