FME 2020: What is the equivalent tool in FME to “Planarize” in ArcGIS?
  • Jan 24, 2021 9:12 PM UTC
  • 6 replies
  • 151 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out if there is an equivalent tool in FME to “Planarize” in ArcGIS
Clip_265
tomf
Forum|alt.badge.img+31
  • Jan 25, 2021 2:28 AM UTC
Try the Intersector, or the TopologyBuilder transformers. Both will split lines like "Planarize" as far as I can tell
jamal
  • Jan 25, 2021 6:58 AM UTC
Thank you tomf
But how to clean duplicates (overlaps) being identified by Intersector and TopologyBuilder tools?
Clip_20Clip_21
tomf
  • Jan 25, 2021 7:42 AM UTC
WIth the Intersector the overlapping line segments are reduced to a single line segment. From the Edge port of the TopologyBuilder, you can use a Matcher to find matching geometries and just keep the SingleMatched and NotMatched features. For a pure geometry match unselect Check Attributes in the Matcher parameters. You can also use a tolerance here to find close geometry matches
jamal
  • Jan 25, 2021 7:07 PM UTC
It appears that the TopologyBuilder splits the lines where they are overlapped while the Matcher has no thing to do when it comes to clean the duplication.
Clip_267
tomf
  • Jan 26, 2021 2:01 AM UTC
The Matcher works fine when you set the parameters as I suggested. The only thing else I added (which made no difference in this example) was to allow Lenient Geometry matching, i.e. drawing direction is ignored when matching geometry.
I get 4 Matched features, 2 SingleMatched and 4 NotMatched. By taking just SingleMatched and NotMatched ports, the overlapping line parts are dropped.
_matcherParams_matchoutputNote: the Intersector outputs just 6 line segments and 8 nodes. So, here the overlapping line segments are already cleaned.
jamal
  • Jan 29, 2021 10:02 AM UTC
Thank you tomf.
The intersector, topolgybuilder, and macher tools appear to do the job
Clip_296
Clip_297
