FME 2016 will support in Window 2019 server ?
  • Dec 19, 2022 6:23 PM UTC
  • 5 replies
  • 38 views
https://community.safe.com/s/article/legacy-fme-technical-specifications#FME2016 in this document is not mentioned about support for window 2019 server.
Can anyone confirm ?
hkingsbury
Forum|alt.badge.img+73
  • Dec 19, 2022 11:01 PM UTC
Seeing that FME 2016 predates Server 2019 by 3 years i'm not surprised. Is there any particular reason you're still using 2016 rather than a newer version?
we are still running legacy application which is going to deprecated later. No plan to move FME latest version. My question was there Window 2019 server will support FME 2016 or not ?
kailinatsafe
Forum|alt.badge.img+24
Hello @avinashdalvi_​, thanks for posting! Unfortunately, I don't think FME 2016 is supported on Windows Server 2019 (otherwise it would be mentioned in the article). It looks like support for Windows Server 2019 starts for FME 2020.x Platform Support. I also recommend trying to upgrade FME versions, if/when it is possible! Hope this helps, Kailin.
when it is not mentioned it is not officially supported or technically also not supported. I am trying to checkout possibility.
kailinatsafe
Sorry for the confusion there! It is not supported! Apologies 😔 Best, Kailin.
