[FME 2016] Is it compatible with PostgreSQL 10 ?
  • Mar 24, 2020 3:34 PM UTC
  • 48 views
faouzi
Participant
Forum|alt.badge.img+13
Currently I use version 9.4 of Postgres and soon we will upgrade to version 10 or 11 of postgres, I would like to know if we can still keep the 2016 version of FME? in other words, is FME Desktop 2016 compatible with PostgreSQL 10?
thank you in advance
@faouzi I have been using FME 2019 & 2020 with PostgreSQL 11.1 without any issues. We do not test older versions of FME against newer versions of 3rd party applications so I can't comment on FME 2016 and PostgreSQL 11. But in general I'd say PostgreSQL has been very stable when updates are made. PostgreSQL is very light weight so it should be easy enough to install on a small test machine. If you're updating your database I'd recommend updating FME since 2016 if five releases old and just going off support.
