FME 2015.1 OpenJDK
  • Feb 28, 2026 7:26 AM UTC
  • 129 views
dthiky
Participant
hi All, i am currently using FME2015, May i check if we are able to use openJDK to replace JRE so that we do not need to use Java Oracle license? Thank you.
Best answer by steveatsafe
​@dthiky
I believe this would be a risky move…
To even have a chance You would need to consider using the equivalent OpenJDK version from that era (see your FME 2015 installation - OpenJDK 8u20 – 8u66).  I think over all this will likely fail but one never knows.  Backup, Backup. And backup again.
Lastly, I’m sure you know what’s coming but it’s probably time to upgrade to a new version.  As you know, this version is no longer supported.
steveatsafe
Forum|alt.badge.img+16
  • Mar 4, 2026 12:58 AM UTC
​@dthiky
dthiky
Participant
  • Participant
  • Mar 4, 2026 1:52 AM UTC
Thank you so much for your advice, Steve!
