Finding all date attributes in a table
  • May 5, 2023 3:01 PM UTC
  • 55 views
markcoopersdc
Hi
I am reading various tables from Oracle each of which contain many date attributes. Is there a transformer that will allow me to filter out all the attributes that are have a type of date as I want to check the dates make sense (I know there are some with some very dodgy data in and wont write out to a sql table)
Thanks
  • May 5, 2023 3:30 PM UTC
If the Oracle table columns have proper DATE or TIMESTAMP data types, you can query the Oracle metadata tables for the column names using an SQLExecutor. See e.g. https://dataedo.com/kb/query/oracle/find-all-date-and-time-columns
This would make it much easier to know in which columns to look.
Alternatively you can also use the AttributeValidator:
