Find similar records and merge them to one
  • Mar 3, 2022 11:58 PM UTC
  • 170 views
messagemauri
I have a table called PROJECTS with some records sharing similar names. The objective is to find these records and merge them to one if possible.
Sample
PROJECTS table with Field1, Field2, Field3
FindSimilar
From the above table, I want to look into Field3 and find similar names, such as Paper Company, Paper Company. and Paper Co and merge these into a single record. They are not exactly duplicates, but share a similar name. There are more records with similar names, so I can't hard-code Paper Company because there are more records alike that share similar names.
What transformers can I use to complete such task?
Thank you.
danilo_fme
Forum|alt.badge.img+58
  • Mar 4, 2022 12:58 AM UTC
Hi @messagemauri​
I simulated here your case and had a great results using the custom transformer FuzzyDuplicateRemover:
Workspace_Duplicate
As you can see, I configurated the ratio of similarity for 70 %.
Results - Unique:
UniqueResults - Duplicate:
Duplicate
Thanks in Advance,
Danilo
messagemauri
  • Mar 4, 2022 5:56 PM UTC
Hi @messagemauri​
Workspace_Duplicate
Results - Unique:
Duplicate
Thanks in Advance,
Danilo
Thank you @danilo_fme​ . This will give me a starting point. 👍
danilo_fme
  • Mar 4, 2022 5:58 PM UTC
Awesome! Thanks your feedback @messagemauri​
