Find neighboring points
spiderman
Forum|alt.badge.img+7
Hello ,
i would like that each point to find the neighbor point .each point connects with other by a line .
so I have a starting point ,i should find the neighbor point and the neighbor point find the next neighbor and so on .
my problem :
how to let each point to stop looking for the neighbour point if the next point is a starting point because some points are connecting to starting point
FME 2021
geomancer
Forum|alt.badge.img+50
  • July 3, 2023
Can you describe the end result you are looking for? Or provide a sketch?
Are you looking for a situation where all points are part of one network, in which every point is connected directly to 2 other points (except for 2 end points, that are only connected directly to one other point)?
Or are you looking for a tree structure? Or something else?
spiderman
  • July 3, 2023
@geomancer​
I am looking for all points ,that connects together
as example
in case point connect with 2 point
point a connect with point b
point a connect with point d
in case point connect with one point
point b connect with point e
in case the point connect in 3 direction
point e connect with point f
Point e connect with point g
point e connect with point k
all point above find the next neighbor
I need to extract this information
what is the neighbor point of each base point ?
u could say ,that I am looking for tree structure .
but in case i started from point a
and one point later connects with point a so i do not need it to look for more at this direction Bcs k have found the points from point a before
geomancer
  • July 4, 2023
If you are looking for something like a Minimum Spanning Tree, it looks like there is no simple solution in FME. This article uses FME and R.
Edit: For ideas for a Steiner Tree see this article using FME and Python.
Thank you, you saved my day.
spiderman
  • July 22, 2023
I am looking for a tree structure ,how could I start ?which ideas should I follow ?
geomancer
  • July 24, 2023
Please see my reply from July 4.
