Filepath Error Warning in FME2022
  • Nov 21, 2022 6:15 PM UTC
  • 0 replies
  • 22 views
Wondering if anybody have encountered the following issue before. I notice that in FME2019, I can put in any file paths (even non-existent ones intended for C:\\Temp) by text editor. FME2022 seems to block it with a warning and I cannot click OK in the dialogue whenever that happens. This happens both within Transformers and with Readers/Writers.
Is there’s a new setting or a toggle switch somewhere that will bypass the warning? This screenshot illustrates the problem when I’m trying to upgrade a EMailer transformer to 2022 version (from 2019).PathError_example
