File matching
fmesafe.podpora
Forum|alt.badge.img+11
Hi, can i somehow parse this file? I would need individual codes separated by a hyphen as the values of one attribute, for example the column name will need ICAO and each code will have one row.
Thank you very much
Best answer by geomancer
If I understand your question correctly, you can use an AttributeSplitter and a ListExploder.
ad_cacd
tomfriedl
Forum|alt.badge.img+13
  • June 15, 2022
Can you give us a example of the result?
geomancer
Forum|alt.badge.img+50
  • June 15, 2022
ad_cacd
fmesafe.podpora
Absolutely great including a description of the settings !!! Thank you very much
fmesafe.podpora
thank you for your interest, resolved
