Extracting subset of data from regular mesh of points
  • November 17, 2020
  • 9 replies
  • 33 views
gerard
Participant
I have a shapefile containing points distributed every 5 meters in a regular mesh of 100 rows x 100 columns. I have to create a shapefile with points of this regular mesh located every 10 meters, or 20 meters, ... (always a number multiple of 5) to get a sparse mesh from the original.
I there any FME Transformer that can help to do this task?
Any suggestion or idea would be really appreciated. Thank you !
Best answer by ebygomm
gerard wrote:
Thanks @ebygomm​ ,
No, the coordinates of points are rounded UTM coordinates and these points are measuments equally spaced over terrain
Have you considered creating a Point Cloud from your points and then using a Point Cloud Simplifier?
Forum|alt.badge.img+39
  • November 17, 2020
Are the coordinates of the points multiples of 5?
gerard
Participant
  • Participant
  • November 17, 2020
Thanks @ebygomm​ ,
  • November 17, 2020
gerard wrote:
Thanks @ebygomm​ ,
It still should be possible with a bit of maths, but hard to say exactly what without seeing the data
gerard
Participant
  • Participant
  • November 17, 2020
gerard wrote:
Thanks @ebygomm​ ,
Thank you very much for your help, @ebygomm​ , I have attach a very small sample data in Shapefile format.
I have simplified at maximum the file structure, because the real data have hundred of attributes.
In this sample data the distance between points is 20 meters, but the idea is to obtain a mesh with a points located 40 m, 80m, ... from each other.
The real problem is that I have a very huge file of points (tens of millions) equally spaced.
I am able to work with this points at map escale E1:5,000 but I have to generalize this points to increase speed of rendering for map escale E1,000,000.
Any idea or suggestion about generalizing points for optimizing visualization at multiple scale maps are welcome. Thank you !
  • November 17, 2020
gerard wrote:
Thanks @ebygomm​ ,
gerard
Participant
  • Participant
  • November 17, 2020
gerard wrote:
Thanks @ebygomm​ ,
I thought PointCloud structures was only for LAS files (specific format for Lidar points).
OK, I will try Point Cloud Simplifier Transformer and also Point Cloud Thinner as explain here: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pointcloudsimplifier.htm
 Thank you @ebygomm​ !
  • November 18, 2020
gerard wrote:
Thanks @ebygomm​ ,
Use a PointCloudCombiner (ignore the name Combiner) to create the Point Cloud from your shape file first
gerard
Participant
  • Participant
  • November 18, 2020
gerard wrote:
Thanks @ebygomm​ ,
Yes, I'm just doing that right now.
I have used: shp-reader -> PointCloudCombiner -> PointCloudThinner -> shp-writer
Also, I can preserve attributes of individual points as components with "Attributes to Preserve as Components" section in the PointCloudCombiner parameters.
I'm trying to undersand why from 19 input points, PointCloudThinner generates 9 (it's ok), but in the workflow schema you can only see 1 (???)
 schemapCloudThinner
gerard
Participant
  • Participant
  • November 18, 2020
gerard wrote:
Thanks @ebygomm​ ,
This combination works: shp-reader -> PointCloudCombiner -> PointCloudThinner -> PointCloudCoercer -> shp-writer
Thank you @ebygomm​  for your help !
schema2
