Extract Published Parameter from server log (Request data section) as posted in the image?
I have a workspace1 when completed posts the topic message to another workspace2 that subscribes to it. I get details about the status of the workspace1 which is received via the JSON file in the topic message (FME_TOPIC_MESSAGE). Is there also a method to extract the published parameters of workspace1?
I tried HTTP caller with the link to the log file with a GET request but I am not able to achieve it
Best answer by virtualcitymatt
You should be able to use the REST API to get this info
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/transformations/request_get_23
virtualcitymatt
Forum|alt.badge.img+36
  • November 23, 2021
  • November 23, 2021
Thank you! Works like a charm :)
