Extract Only Trunk Lines
  • Jul 18, 2018 7:03 AM UTC
  • 7 replies
  • 187 views
parashari
Hi, I have a road network(polygon) from where I extracted the center line. But, since there are donuts and holes in between the areas, it is not getting possible to extract the center line on a medial axis using CenterLineReplacer, so I am using the straight skeleton mode. But, it has too many short lines connecting the trunk line. I have tried using topology builder and list element counter to find the junction nodes to remove the nodes having just 1 junction. But, since there are multiple short lines connected, it is still not possible.
Is there a way to do it?
  • Jul 18, 2018 8:36 AM UTC
You may want to try the FME 2019 beta, apparently the CenterlineReplacer has gotten a new setting that should improve such cases, see the comment by Mark here:
https://knowledge.safe.com/questions/31926/cleaning-gps-line-work.html
Since I cannot find the 2019 beta on the download page just yet, you may need to contact Safe support to try it out.
FME 2019.0 betas should be available to download by the end of July!
parashari
  • Jul 19, 2018 5:41 AM UTC
Thanks, @david_r, and @hollyatsafe
Any other workaround till then? Like there are problems like below as well. If I try to use centerline replacer, the output goes in rejected( my data is single feature).
  • Jul 19, 2018 10:42 AM UTC
I would be mighty impressed if the new CenterlineReplacer was able to do anything sensible out of the box with that polygon...
fmelizard
Forum|alt.badge.img+22
  • Jul 19, 2018 3:24 PM UTC
@david_r @hellblazer Here's what I get with the new Approximate Center Line mode in 2019:
parashari
  • Jul 20, 2018 4:05 AM UTC
Wow. Well, that's the closest output that I have seen with just one transformer. I hope this will reduce at least 10 transformers(since I am working on parallel data) thereby reducing time and effort. I suppose the unwanted small lines can be removed using generalizer or topology builder. Thanks @DanAtSafe
  • Jul 20, 2018 7:23 AM UTC
@DanAtSafe I'm impressed :-)
