Extract attribute from autocad
  • Mar 30, 2022 8:14 AM UTC
  • 129 views
mazenaldaas
Forum|alt.badge.img+7
Hi all,
Is there any way to extract the area and length attribute from the cad file.
I tried AttributeExposer but i couldn't extract area and length..
nielsgerrits
Forum|alt.badge.img+67
I think these are geometric properties in cad, not attributes.
In FME you can calculate these using the LengthCalculator and AreaCalculator.
mazenaldaas
  • Mar 30, 2022 10:06 AM UTC
Yes you right and i know that i can use LengthCalculator and AreaCalculator but the Number of digits after the decimal point will not be the same.
I need to extract the Area and length with the same number of digits after the decimal point.
danminneyatsaf
Forum|alt.badge.img+13
Hi @mazenaldaas​ would you be able to share some of the results you get from the LengthCalculator and the AreaCalculator? Are the transformers producing too many digits after the decimal point or not enough?
mazenaldaas
  • Mar 31, 2022 7:14 AM UTC
sure ..
You can find the difference of the created digits after the decimal point by using the AreaCalculator and the number of digits after the decimal point in the first image..
The highlighted record cantons the calculated area for the same polygon in the first image.
