Exposing the X and Y Coordinates of a line
  • Jan 22, 2021 5:49 PM UTC
  • 288 views
inframan
I have a shapefile, it is all lines with only two points in each line. Ultimately I'd like to expose the X and Y, start and end, of each line. CoordinateExtractor seems to be able to expose the X and Y of all the points but is there a way to filter that list, like Start X, Start Y; End X, End Y?
Best answer by DanAtSafe
Hi @inframan​  You could use two CoordinateExtractors to get both coordinates without a list. The first coordinate is 0 and the last is -1.
DanAtSafe
Forum|alt.badge.img+23
  • Jan 22, 2021 5:55 PM UTC
inframan
  • Jan 22, 2021 8:15 PM UTC
That worked, I put two Extractors inline then changed mode to Specify Coordinate and changed the names to x_a, y_b, etc. Thanks.
