Export graphic from FME inspector
  • Jul 10, 2019 5:09 AM UTC
  • 166 views
tannyngtf
Hi ALL
I have created straightline diagram and can be viewed in FME Inspector. I also write into ACAD but I find that the ACAD output not as pretty as showing FME Inspector.
Is there a way to save the graphic from FME Inspector or export same format as it shown to a file?
Regards
jovitaatsafe
Forum|alt.badge.img+11
Hi @tannyngtf,
I'm not 100% sure for your data, but try going to File > Save data As in the Data Inspector, and save it as a 3D PDF format.
It should successfully write out a pdf graphic of your data. You can also do this with selected portions of your data using 'Save Selected Data As'.
Otherwise perhaps a screenshot maybe easiest to get a quick view.
gio
Forum|alt.badge.img+15
  • Jul 11, 2019 11:11 AM UTC
.you might be confusing the data viewed with the rendering.
Pretty pictures are best made with Inkscape (and of course Illustrator.)
Inkscape can be (partly) driven trough fme.
You can create a rster form the data. With Mapnikrasteriser you have full control.
Or if you want to keep the geometry, export the required settings to whatever 2/3D program. Inkscape for instance.
