Export a localized point on a map with background
  • Sep 11, 2020 8:11 AM UTC
  • 95 views
Location_mapHello !
I would like to know if it is possible to have a mapping background on which is situated a localised point, as shown in image below ? I have more than a hundred located points and I need to generate automatically this kind of map in PDF format if possible, on which there shall be TEXT inserted such as title, XY cordinates and a jpeg photo.
Anyone could help me to create this workbench please?
Thanks in advance !
  • Sep 11, 2020 8:17 AM UTC
Hi
You might want to look at this post. It is what you want if I understood correctly. Only the inputs are different, but it shouldn't be a problem.
Hope this helps
https://community.safe.com/s/article/creating-pdf-cartographic-output-2016?childToView=37456
  • Sep 11, 2020 8:57 AM UTC
Hi
Hope this helps
Hi !
Yes, it will definitely helps me !
Thanks a lot.
