Exercise in training module refers to MapInfo file which isn't included
  • Aug 22, 2023 7:18 AM UTC
  • 29 views
mapixse
View Data > Exercise: Customize Your View
https://safe.my.trailhead.com/content/safe/modules/view-data/exercise-customize-your-view
Used the geojson as input instead, worked out fine.
exercise-customize-your-view_mapinfo
samatsafe
Forum|alt.badge.img+12
  • Aug 22, 2023 3:51 PM UTC
Hello @mapixse​, thanks for pointing that out. You should note that the writer in that workspace is GeoJSON. The issue is that the previous exercise doesn't have you build a workspace, so using a starting workspace in the next exercise is confusing. It also doesn't include the KML file as it should. I've noted to clarify these instructions when we update this content. Thanks for pointing it out.
