Excelwriter bug?
  • Jul 21, 2022 4:13 PM UTC
  • 110 views
connecter
Forum|alt.badge.img+10
today I have a problem with the excelwriter. I create a simple workflow:
imageThe result in excel:
imageWhy is it insert a comma and not a dot?
The Data Inspector also show different types:
imageBest regards,
Florian
Forum|alt.badge.img+54
  • Jul 21, 2022 7:05 PM UTC
The comma is based on the decimal separator set in your system settings in excel. If you set the type to number in the writer you should see a consistent output for all three attributes. What's a bit odd is that the setting of string in the excel writer doesn't seems to give inconsistent results depending on the fme data type when viewed in excel
connecter
  • Aug 20, 2022 1:48 PM UTC
Sorry for the late answer. 😊
I have test it further and the fme interpreted it wrong or rather it wound't transform correct in the excelwriter. It should be a string. A workaround is the StringFormatter with the "Format String option" of .2f.
