Error with json conversion.
  • May 25, 2019 5:55 AM UTC
  • 9 replies
  • 100 views
Destination Feature Type Routing Correlator(RoutingFactory): JSON Writer: Cannot create dataset: 'C:\\conversions\\183d5013e531487c96a18afef4527d48\\2549_6672.json' of type Directory, expected a dataset of type Regular file.
Why im getting this error @virtualcitymatt,@markatsafe.im unable to get the output.I have attached the workspace please check it.What is giving me error.
nampreetatsafe
Forum|alt.badge.img+14
I wasn't able to reproduce the same error when I ran your workspace. It actually ran successfully with a json output in C:\\test\\gml_data\\sample.json. I tried it with both FME 2018 and FME 2019.
I don't see anything in your workspace referring to 'C:\\conversions\\...'. Is there anything else you can tell us about your environment which might help explain why you are getting this error?
I noticed you were working on a similar error in a Forum Post from December (dxf to GEOJSON)... were you able to resolve that issue?
  • May 29, 2019 3:45 AM UTC
Actually im not this process manually,im doing it using code by running the command line,im getting error when im doing the conversion using the code,its creating a folder with .json but not json,but when im running the conversion command manually the conversion is happening.What colud be the reason.Even dxf to geojson conversion is also having same issue.Converting to other formats is working fine with my code,but im getting error only with json output.
nampreetatsafe
I see. Are you running it in command line or something else? Are you able to share the code/argument(s) you are using to run the workspace?
  • May 30, 2019 9:45 AM UTC
Yes im running the conversion in commandline.
"C:\\Program Files\\FME\\fme.exe" C:\\test\\gml_to_json\\gml2json.fmw --SourceDataset_CITYGML "C:\\Users\\Administrator\\Desktop\\sample.gml" --FEATURE_TYPES "RoofSurface" --DestDataset_JSON "C:\\Users\\Administrator\\Desktop\\test_data\\test.json"
is the command im running.I was able to convert by executing the command manually.But when im trying to do it with code im not getting the json output its creating a folder with the given json name.
I executed the same code for other data type conversions they all converted and got correct output.But im getting issues only with json what colud be the reason.Where im going wrong.
nampreetatsafe
Thanks @san! So we can try replicating the issue, can you please tell us exactly how your are running the command with code?
dellerbeck
Forum|alt.badge.img+7
  • May 30, 2019 8:11 PM UTC
I have noticed some odd issues with complex paths or filenames in recent releases especially when working with a *nix OS like Mac but my Windows VMs have had the same issue. I have had to use a creator and add the path to the record, then use a feature reader and map the path to the attribute.
I changed the workbench you attached, hope this is the same issue you are having and it works for you.
FeatRead_citygml2json.fmw
  • May 31, 2019 6:13 AM UTC
Still getting the same error.
JSON Writer: Cannot create dataset: 'C:\\conversions\\f114f22c-1e27-4b2f-955a-1f9621713485\\0664_M-34-47-C-b-4-4.json' of type Directory, expected a dataset of type Regular file.
I'm not knowing why this error is occuring. I have followed the process u have mentioned.
It was giving error when running through code.But when im running the same command obtained from the code manually its giving me output.All other conversions are working fine with my code.Only json output is troubling me.
nampreetatsafe
What code you are using? If the workspace is running fine manually and using cmd, I'm wondering if there's something in the code you are using that might be causing the error.
nampreetatsafe
If you are using FME objects, a fellow Safer suggested that we generally recommend using the FMEWokrspaceRunner method as this should behave exactly the same as running a workspace in FME Workbench. Check out this tutorial which demonstrates this: Run an FME Workspace from Python using FMEWorkspaceRunner. I hope this helps!
