Error while installing FME 2019 server.
  • Dec 18, 2019 7:32 PM UTC
  • 51 views
We are trying to install FME 2019 server. After the installation was completed, we tried to trigger one job from the samples repository. However it is giving the following error:There was an error submitting the job. COM.safe.fmeserver.api.FMEServerException: java.sql.SQLException: Key not found in configuration table: pause_queue_incoming. Please help.
siennaatsafe
Forum|alt.badge.img+12
Hi @karan_dixit,
Thank you for contacting Safe Support. I see you have a case which is the best way to reach us for a question like this. Unfortunately, I can't find any other cases with that specific error message. The good news is that often better and more detailed errors can be found in the FME Server logs. If you could please send a zipped up version of your entire log folder to your case that would be the best way to start figuring out this problem.
Kind regards,
Sienna
