Error :Invalid line geometry after using network topology calculator
  • Aug 14, 2023 3:15 PM UTC
  • 156 views
spiderman
Forum|alt.badge.img+7
Hello ,
i got 6 lines at rejected port from network topology calculator transformer .the reason is invalid line geometry .
How could I fix it ? What does the reason and what should I check ?
FME 2021
thanks in advance .
  • Aug 14, 2023 3:20 PM UTC
I would start by checking the number of coordinates (>= 2) and the line length (> 0). You could also try saving a few rejected features as FFS and post the file her.
spiderman
  • Aug 15, 2023 4:34 AM UTC
Thanks, I will check them today
