DuplicateFilter issue with the same value attribute in two features
  • Jan 4, 2022 1:02 PM UTC
  • 6 replies
  • 113 views
jorge_rosales
Forum|alt.badge.img+8
In attached workspace I get unexpected DuplicateFilter behavior,
DuplicateFilter test workspaceThe Inspector result is,
DuplicateFilter test featuresSince the two features have the same value for the nombre_cientifico attribute, I am confused with the unique port output. Any suggestion?
Best answer by DanAtSafe
Hi @Jorge Rosales​ This problem with the DuplicateFilter appears to be fixed in FME 2022.0 Please let me know if you can't use FME 2022 beta yet.
Forum|alt.badge.img+54
  • Jan 4, 2022 2:40 PM UTC
Have you checked for trailing spaces?
jorge_rosales
  • Jan 4, 2022 3:27 PM UTC
Yes and text encoding as well.
  • Jan 4, 2022 4:03 PM UTC
Definitely something odd going on there, the matcher considers them to match. If you change the Preserve Feature Order to across output ports it appears to work as expected. One to send to Safe I thinkimage
jorge_rosales
  • Jan 4, 2022 5:11 PM UTC
I hope someone from Safe reads this.
DanAtSafe
Forum|alt.badge.img+23
  • Jan 4, 2022 8:28 PM UTC
jorge_rosales
  • Jan 5, 2022 11:02 AM UTC
Thank you very much for the information @danatsafe​ .
