Drop and Rebuild Indexes when writing to ESRI Geodatabase
  • Aug 7, 2020 3:24 PM UTC
  • 570 views
sunsilk11
Hi I am writing millions of line features to an various feature classes in an ESRI SDE Geodatabase 10.0. Are there any best practices for improving the performance in writing.
I am writing to a non versioned db, which is being used constantly.
I have increased the transaction to 10000. And Set Transaction type to null.
Is there a way to set the writer in load-only mode for the GEODATABASE_SDE?
itsmatt
Forum|alt.badge.img+48
  • Aug 10, 2020 12:54 PM UTC
Here's some info on that:
https://community.safe.com/s/article/writers-and-performance
and also:
https://community.safe.com/s/article/improving-performance-when-working-with-esri-geoda
You asked about dropping and rebuilding the index? That would definitely help, but unfortunalty there is no easy way to do this in FME without a bit of python. https://pro.arcgis.com/en/pro-app/tool-reference/data-management/remove-spatial-index.htm and https://pro.arcgis.com/en/pro-app/tool-reference/data-management/add-spatial-index.htm
Someone might have a sample to share with you.
The other thing to check it permissions, I have heard that if permissions are not high enough for SED FME might try and start and edit session which is much slower. Check that you have proper permissions.
bwn
Forum|alt.badge.img+26
  • Aug 11, 2020 12:58 AM UTC
If it is non-versioned it becomes relatively straightforward to instead Write using the native DB Client, like the SQL Server Spatial Writer (depending on Spatial Data Type being used in the backend). Similarly dropping and re-building the indices can be executed with the relevant SQL commands like DROP INDEX, CREATE INDEX etc. but that involves compromises if you are executing that in a live production environment and is DB dependent.
An alternative way I've found faster for insertions and updates is to send the features in via ArcPy da (Data Access) InsertCursors or UpdateCursors respectively. They are a pain to code up in Python, but it tends to outperform the SDE interface (and related FME Writers) by several orders of magnitude.
itsmatt
  • Aug 11, 2020 7:25 AM UTC
This is really interesting - thanks for sharing.
