Hello, I have a line shape file which is in 2d. I want to drape it on terrain to make it 3d. I have the terrain data of the area which is a .las file.
This should work with a SurfaceDraper. PointCloud into the Points/Linesport and the 2D features into the DrapeFeatures port. https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/surfacedraper.htm
FME will create a surface out of the Point Cloud and drape the features onto the surface. The output features will be in 3D.
Already have an account? Login
