Double field type interpreted as int type - FME 2021
  • Feb 24, 2022 3:52 AM UTC
  • 143 views
Hello,
I noticed something weird with my reader.
The primary key from a Geodatabase_SDE table is interpreted as int type on my 2021 version but is correctly interpreted as a double type on my 2019 version.
Reader's properties on 2021 version :
intV2021Reader's properties on 2019 version :doubleV2019Allowing reader feature type editing won't change a thing. All the id values are set to 0 through the inspector.
Also, double fields type from the same dataset are well interpreted. Both versions.
Thanks for having a look.
Regards.
@yohanl​  Can you please send me an export of the feature class schema as an Esri XML Workspace Document (Schema Only) (you can use ArcCatalog -> Export) ? Which version of ArcGIS Desktop or Pro are you using. Thanks
@yohanl​ Thanks for including the schema XML.
When I import the schema and view it in ArcGIS Pro, it shows the ID field as INTEGER. So it looks like FME 2021 is interpreting the field type correctly. I actually don't see this behaviour in FME 2019 either - in FME 2019.2 , the ID field is interpreted as Integer.
As seen in ArcGIS Pro:
