Does it possible to connect FME Desktop Professional Edition 2020 with Esri software ?
  • Jun 22, 2022 11:51 AM UTC
  • 80 views
joker_
in case not,which license required to connect with Esri software ?
please, could someone explain , what is the difference between FME Desktop and FME Server?
Thanks in advance
chrisatsafe
Hi @joker_​ ,
FME Desktop can connect with Esri Formats like file geodatabase, SDE, etc using the FME Desktop Esri Edition License (assuming the dependencies have been met). The Professional Edition license allows you to make use of the file geodatabase open API format as it does not have a licensing dependency, however. For more on FME<>Esri compatibility please refer to this article. There's also the Data Interoperability Extension for ArcGIS which is based on FME Desktop.
FME Desktop is the authoring environment which is used to build and run workflows using Readers, Transformers, and Writers locally in FME Workbench. This is also the environment where you can visualize your datasets.
FME Server is the automation piece which allows you to publish workspaces from FME Desktop and run them on a schedule, in response to events (file/email received, webhook, and more) using Automations, process data streams, and create server apps.
If you are interested in learning more about how FME can help your organization, please do not hesitate to reach out to info@safe.com or request a Personalized FME Demo.
joker_
  • Jun 23, 2022 6:10 AM UTC
Hi @joker_​ ,
Thanks for good explanation
