Does FME support writing to Citrix Sharefile?
  • Oct 25, 2021 9:06 AM UTC
  • 61 views
chrisatsafe
Hi @wilsons​ ,
It doesn't look like we have a CitrixSharefileConnector at the moment but there is an idea that is requesting this same functionality! Would you be able to upvote and share your use case on this idea post to help motivate the idea?
In the meantime, it looks like Citrix Sharefile has an API so you could use an HTTPCaller to connect to your data on Sharefile. The Getting Started with API's tutorial is a great starting place if you are new to interacting with API's in FME.
