Does anyone have used XSD template file and tried to create a new ESRI geodatabase ? What are developenment steps that I should follow? If you have any hints on this topic it would be very appreciated to share them here. Thanks a lot!
  • Apr 20, 2022 2:30 PM UTC
  • 112 views
madi
Forum|alt.badge.img+8
I have an XML geodatabase file that contains all data and his schema(GDB structure) in XSD file format. I want to create a a new GDB using XSD file structure by extracting all data from xml file and import them in the new GDB.
rahulsharma
Forum|alt.badge.img+12
Hi @madi​
You should be able to use the Template Geodatabase as elaborated in this article
How to use an Esri Template Geodatabase
