Does anyone have experience with running FME Server 2022 and FME Desktop 2021 32-bit using command line to support esri SDE 32-bit dependent readers and writers?
  • Aug 17, 2022 9:12 PM UTC
  • 51 views
geogaard
Forum|alt.badge.img+15
I am just looking into the idea of using desktop instead of a 32-bit engine and if someone has experience with this, good or bad.
richardatsafe
Forum|alt.badge.img+11
Hi @geogaard​ ,
I'm wondering if we can help understand your reason for FME Destkop vs FME Sever. FME Server and FME Desktop engines are the same so the only difference would be missing out on FME Server functionality (Automation, logging, retries, scheduling, outgoing notifications, triggered events, on-demand UI, event failure, self-monitoring, ect.) ESRI licensing and application requirements would be exactly the same. Additionally, Geodatabase SDE is supported on 64 bit FME engines with 32 bit ArcGIS Desktops and background geoprocessing. (the only exception would be custom geodatabase like ArcFM that are written with 32 bit).
