Distance calculation between points datasets
  • Oct 31, 2019 6:10 PM UTC
  • 167 views
fme_can_do_it
Forum|alt.badge.img+13
I have CSV that contains Lat/long. i need to convert this into points using spatial reference WGS 1984. then i have to compare this point data with my building point layer. i need to calculate distance between the points in CSV and the building layer. Building layer has already this CSV data but the locations in CSV has been changed. I need to find the distance in feet.
danilo_fme
Forum|alt.badge.img+58
  • Oct 31, 2019 6:15 PM UTC
Hi @srhjunaid
I suggest you the use the transformer like NeighborFinder.
This transformer generate a new attribute _distance that hold the distance.
Thanks in Advance,
Danilo
