Discrepancy is AutoCAD outputs when running in FME Flow vs FME Form
  • August 24, 2023
  • 10 views
kdwss
Forum|alt.badge.img+3
I've built an AutoCAD based automation in FME Form and use blocks with text for some of the output features. The text aligns how it was designed in the block in the FME Form output.
However, when running in FME Flow the text shifts.
imageIf I move the block slightly or edit the text in AutoCAD then it snaps back to the correctly designed position.
imageI'm using the same template dwg in FME Form and FME Flow.
siennaatsafe
Forum|alt.badge.img+12
Hi @kdwss​
It's hard to tell from this post why this is occurring. It will likely take a support case to dig through this. I'd reach out to your reseller for support.
However, you can check a few things to see if it makes a difference:
  1. Is FME Form and Flow on the same version?
  2. Are they running on the same operating system?
  3. Does running the workspace on FME Form without FeatureCaching turned on make a difference?
If you do decide to make a support case, I'd recommend sending in the workspace and some sample data to help them reproduce locally.
Please let me know if you have any questions!
