Discover user id not FME feature number when processing data in FME Workbench
  • Feb 10, 2023 3:00 AM UTC
  • 80 views
In FME Workbench I have a Bufferer transform which is stopping on a specific feature. FME is reporting:
Bufferer_SC1_2DBuffering (PolygonDissolveFactory): Buffering feature number: 49788
And stops.
How do I find out what feature number 49788 is referring to? What I want is not the FME Feature number but the value of a unique user identifier called search_criteria_pk_id.
regards
Simon
DanAtSafe
Forum|alt.badge.img+23
  • Feb 10, 2023 3:20 AM UTC
@simongreener​ That's the count of the features as they entered the Bufferer. You could use a Counter or a Sampler (the first 49787 should work) but you should be able to identify or even fix the problem feature with a GeometryValidator before the Bufferer.
Dan, I will take a look at Counter or Sampler.
Because I assumed the stopping of the Bufferer was probably related to an input geometry problem, I put a GeometryValidator. Only those that pass the GeometryValidator are sent to the Bufferer.
DanAtSafe
  • Feb 10, 2023 7:35 PM UTC
Please file a case if you find features that pass or are repaired by the GeometryValidator but still cause the Bufferer to crash.
